11-07-2020 02:25 AM - last edited on 01-16-2024 04:20 PM by ZenBot
11-07-2020 10:57 AM
duy1406Download an app called "GPS Test" and provide the app with the location permission. It doesnt matter if you choose all the time or only when the app is in use.Please tell us some basic information before asking for help:
- Model Name: Rog phone 2
- Firmware Version: 17.0240.2009.49
- Rooted or not: Not
- Frequency of Occurrence: GPS doesn't work.
- APP Name & APP Version (If your issue relates to the app): Google map
When I opened Google map, it said GPS signal lost. I tried to factory reset my phone already but it still doesn't work.
GPS problem
11-07-2020 01:36 PM
ronald1985Hi, it shows 11 in view and 0 in use.https://zentalk.asus.com/en/discussion/39671/gps-problem
Go outside and launch the app, you should have satellites "in view" and if it is working, you should see "in use" thats highter than zero.
How many satellites do you have "in view" and how many are "in use"?
11-07-2020 02:47 PM
duy1406I had the same issue last month where I had over 30 satellites in view but none are in use. I also did the factory reset and the reset in recovery too, and it didn't work for me. Then I went ahead and did the below and you can go ahead and do the following as it seem to work for me back then:https://zentalk.asus.com/en/discussion/comment/131015#Comment_131015
11-07-2020 03:13 PM
ronald1985I did all of 2 your solutions but it still doesn't work. It seems the GPS chip is broken I think. So disappointed with the phone's quality. I just bought it nearly 1 year.https://zentalk.asus.com/en/discussion/comment/131022#Comment_131022
Solution 1:
Settings -> Apps & notifications -> See all XXX apps -> (3 dots in the upper right corner) -> Show system -> Clear storage and cache of the following apps:
- Google Maps
- Google Play Services
- Google Services Framework
- LocationServices
- Telephony Services
- Fused Location
- Google Location History
Restart your phone.
Now go outside and see if you have satellites in use.
Solution 2:
If solution 1 doesn't work, then do this:
(You will need to provide relevant permissions for all apps once this is done.)
Settings -> System -> Reset options -> Reset app preferences (this doesn't affect apps data)
Restart your phone.
Do let us how you get on.
