Flickering Right air triggers
Carlo_G
Rising Star I
Model Name:ROG 2
Firmware Version: Latest version WW...2007.27
Rooted or not: NO
Frequency of Occurrence:ALWAYS
My right air triggers is flickering when I'm holding it while playing or just in the settings adjustments for air triggers, and I'm cautious when it comes to my phone. The left Airtriggers seems to be fine and working well but the right Airtriggers are flickering. Will this be fix on the next FOTA? I'm not sure if this is a bug for the latest version.
7 REPLIES 7
Carlo_G
Rising Star I
Waiting for the FW update. If it's not fix with that specific FW patch update then this is a hardware issue. Even no case on the phone the issue still persist. I hope this will only be software issue because i don't use to much the right Airtriggers and i used it with care. My phone is only 3 months old and this already happened. Tried to clean the triggers but no luck.
ruyolmos_zero
I add myself to the problem list, I bought mine in march and since I dont' play a lot of games, I didn't noticed before, but as I see, there's a lot of ppl experiencing the same problem, the flickering trigger is the right one in my case, We need that Fw Upgrade 😞
Gustav_ASUS
Community Legend III
@ruyolmos_zero Which firmware update are you on right now? The flickering issues should have been taken care of in the 2009.47 update.
