DTS audio is not getting enabled automatically
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-18-2019 02:28 AM
Hello team,
DTS audio is not working properly. Everytime, I have to open the audio wizard and select any audio mode (eg. Rock) when I play music with any music player. Could you provide solution for this issue.
39 REPLIES 39
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-25-2019 09:08 AM
Anders_ASUSWired headphones...i used Amazon prime music and hungama music app. Also make sure to quit audio wizard after you select a mode... Select a mode while listening songs...quit the audio wizard..ask someone to call you .once call is over listen to same song you will notice DTS x mode is disabled.here you have to go again to audio wizard , click custom to reactivateI tried without luck replicating the issue using spotify. Are you using BT headphones. Does it happen all the time and right away?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-25-2019 09:20 AM
Yes I use Wired headphone, I missed to mention this in my previous note.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-29-2019 09:38 AM
i too face this issue. i have to open audio wizard and select the effect to apply it. this issue happens if i play music after long time(few hours) or if i answer a call inbetween.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-29-2019 01:51 PM
In my case it was off by factory. First time I plugged in my headphones I have enabled it, set to WIDE and since then it stays on all the time.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-08-2019 05:57 AM
It is still happening for me. @Anders_ASUS Do you have any update?
