{BUG] Screen unresponsive when connected to Car Head Unit (Android Auto)
anthonws
It seems that I can repro pretty easily the situation where if I connect my ROG Phone II, to my Citroen Spacetourer head unit (for Android Auto), I cannot double tap to wake and neither I can swipe up, to dismiss the "Android Auto Lock Screen".
Only when pressing the power button I can actually unlock the phone using the fingerprint.
Also. Even after disconnecting the phone from the head unit (usb), it requires a power button press for on/off the screen, so that touch works again.
Apparently, this is a known issue since other users reported the same behavior in ROG PHone II Telegram group.
Please advise on what logs/evidences are required.
Cheers,
anthonws.
LP_ASUS
Community Legend I
I sent you a PM with the log tool and instructions.
