Battery issue ?
varnavas
After I charge my phone I check it after 2-3 and see that . What is mean ? My battery need to replace ? The issue came from Android 11 or what how I can check it to see what it is the problem ?
7 REPLIES 7
varnavas
ronald1985
https://zentalk.asus.com/en/discussion/comment/204485#Comment_204485
Viber seems to be the culprit here. Do you use it regularly?
Likewise, you are also on 120hz refresh rate - that can cause unneccessary battery usage when apps don't utililise the full refresh rates.
No I do not use it regularly I was on call with a customer to give him a support. So your opinion is to turn down the Hz ?
varnavas
Volodesi
Too bad the Battery tracking doesn't show the average screen brightness. Could also help if that information was given.
My brightness always is on the middle with night light on always
ronald1985
Community Legend I
varnavas
https://zentalk.asus.com/en/discussion/comment/204491#Comment_204491
Its up to you. You can give a try to run it at a lower refresh rate and see if you run into the same drainage issue.
