Battery Issue on Rog Phone 2
My phone's battery is being drained very quickly. Even on the stand by mode, there is a drastic change in the battery drop. Please help on this issue.
ronald1985
Community Legend I
Vaibhavbalotra
Drain your battery to zero percent and then charge your phone to 100%. Once 100%, let it discharged by 1% (discharge to 99%), and then charge your phone to 100%, leaving on 100% for at least 15 minutes.
Please also provide more information:
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
ARP_ASUS
Community Legend II
Hey Vaibhavbalotra,
Can you share the SOT(Screen on Time) after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
ronald1985
https://zentalk.asus.com/en/discussion/42789/battery-issue-on-rog-phone-2
  1. Model Name:
  2. Firmware Version:
  3. Rooted or not:
  4. Frequency of Occurrence:
I just saw your reply.. I'll try this now and will revert back the feedback asap.
