08-09-2020 03:39 PM
08-12-2020 08:53 PM
ausaras@gmail.comHere is the thing, I am using my battery to 100% without overcharging it. May be after 1 year or 1 and 1/2 half year, my battery capacity will degrade to 80%. However, your battery capacity is 80% from day 1 as you are charging your battery to 80% only. That means your battery is already degraded by yourself. Then what is the use of 6000Mah battery if you are using it like 4800Mah battery.https://zentalk.asus.com/en/discussion/comment/103037#Comment_103037
I forgot where I read the same information. Li batteries are most comfortable between the 20% - 80% range.
My previous phone was Oneplus 6. Before owning Oneplus 6, I always kept phone plugged in most of the day so battery is almost always above 80%. And every phone's battery started to degrade rapidly after 1 year...I thought this was normal. But by the one year mark, I usually pass the phone to someone else so this did not matter to me much.
Then, I bought Oneplus 6 and read the 20-80% range information. So, for Oneplus 6, I mostly kept it around that range. I used Oneplus 6 for 2 years and battery degradation was MUCH less than all the other phones before it. I was planning to keep using it but I dropped it one night and its screen broke.
Because I need a phone urgently and did not have a backup phone, I purchased ROG 2, which I have been interested for a long time but the price was a bit too high for me, especially when the Oneplus 6 was still working well. Anyway, in the end, I bought ROG 2 despite the high price...was going to wait for ROG 3 but the lack of earphone jack turned me off.
In summary, keep your batter between the 20% - 80% range most of the time. It REALLY does make a difference!
08-12-2020 10:18 PM
SoumyaRSA battery suffers from higher wear levels over 80% the cycles on your battery depend on how you charge it what you just said makes no sense sorry you need to read more on it as it seems you don't understand how cells work, I know what you are trying to say but it doesn't work that way, 100% charging your battery will put more wear on the battery and increases degradation for anything over the 80% but every battery is different and there are different types of cells that require different charging habits, if you are unsure let me know and I can link you to some informationhttps://zentalk.asus.com/en/discussion/comment/103044#Comment_103044
If I am getting 9 hours of SOT from day 1, you will be getting 7 hours of SOT. After 1 year may be I will be getting 7 hours of SOT AND you will be getting 6.5 hours of SOT.
SO HOW DOES THAT INCREASE YOUR BATTERY LIFE?
08-12-2020 10:19 PM
SoumyaRShttps://zentalk.asus.com/en/discussion/comment/103044#Comment_103044
08-12-2020 11:19 PM
kyleashcraft86Yes! There's always a risk (small but definitely there) with restoring a backup since it may bring back the very thing that caused the battery drain.https://zentalk.asus.com/en/discussion/comment/103000#Comment_103000
Alright I'll give this a try. Obviously sending it out is the last resort. I assume once I do a factory reset I would just install apps one by one? Instead of from a backup?
08-13-2020 01:06 PM
