12-08-2019 07:29 AM
12-08-2019 02:19 PM
12-16-2019 05:12 AM
Rajat KumarI don't have any thoughts. There's so much that the battery stats are not showing.Extra information on the state of the phone -
Refresh rate always at 120Hz.
Spent 50-50 of the battery on gaming and general use.
And alternating between gaming and general use.
No battery saver used .
Brightness was kept adaptive.
Phone was always connected to wifi.
@Anders_ASUS @LP_ASUS your thoughts on this ? As i did this test just to confirm the battery recallibration that was talked about in a previous thread.
12-16-2019 05:14 AM
Anders_ASUSWell I was unaware about that now I will try that and lets see what results I come across.https://zentalk.asus.com/en/discussion/comment/33099#Comment_33099
If you want to show your battery life, then you need to run a benchmark like PCMARK at 50% brightness and with flight mode turned ON. Why flight mode? Because one of you might be in an area with bad reception and that will consume a lot more battery life since the antenne needs more amplification. You will also prevent background apps from transmitting data. Oh, and please state if you're running in 60, 90 or 120Hz
https://play.google.com/store/apps/details?id=com.futuremark.pcmark.android.benchmark&hl=en
12-16-2019 05:17 AM
12-16-2019 05:31 AM
