01-18-2020 11:26 PM - last edited on 01-16-2024 01:09 AM by ZenBot
01-20-2020 10:38 PM
Anders_ASUSOh yesCould it be that you have made some changes in Audio Wizard? If you did then don't 🙂 AudioWizard steals the audio stream from the system lightning and the only way to get it back is by re-enabling the aura effect in Armoury Crate.
We're working on trying to find a workaround for this
04-30-2020 02:45 AM
06-02-2020 03:29 PM
06-02-2020 11:41 PM
jumapao28There is nothing changed between old and new android.Im using rog 2 and Lighting aura in android 10 sucks i cannot choose how the light works in calls and notification its just a default set up .. android 9 was better i can choose what light it will display on calls and notifications. please return old version of it.
