Audio doesn't work on whatsapp, messenger, duo when connected to bluetooth headset
Audio (both mic and speaker) doesn't work when connected to a bluetooth device in calling apps like whatsapp, messenger, viber and it doesn't work on other apps like PUBG team chat. This is a recent issue happening after Android 10 update. Is it only my device or does any other users have this bug as well?
1 ACCEPTED SOLUTION
Accepted Solutions
ronald1985
Community Legend I
suveenkumar.vundavalli
I just tried using my car bluetooth, seem to be no problems.
I know you said it didn't happen pre Android 10 update. But can you do one thing and turn of Developer's Options.
If you can, can you state which bluetooth headset you're using so the moderators here will know. If you have other bluetooth devices, give them a try and see if that works.
9 REPLIES 9
I use oneplus wireless bullets 1.
ronald1985
Community Legend I
ronald1985
https://zentalk.asus.com/en/discussion/32235/audio-doesnt-work-on-whatsapp-messenger-duo-when-connec...
Thanks @ronald1985 turning off developer options seems to work. BTW, I was using oneplus wireless bullets v1. I also tried with oneplus wireless bullets Z before and it had the same issue.
https://zentalk.asus.com/en/discussion/comment/98220#Comment_98220
@ronald1985 After few whatsapp calls, it stopped working again. The developer options are still turned off. Same problem with oneplus wireless bullets v1 and oneplus wireless bullets z.
