03-17-2020 02:19 PM
03-18-2020 01:14 PM
03-19-2020 04:15 AM
03-19-2020 06:37 AM
03-19-2020 07:39 AM
03-19-2020 07:44 AM
kartonickBruh you didn't use facebook. Chrome is used less. YouTube is nowhere. Not a good comparison. I agree with you that a10 has a bit of battery drain but You're misdirected. It wouldn't have been 19% if you'd have used almost exactly the same as a10 but it would be closer to 30.Just to compare with reverted phone to android 9 (manager to gry it running)
Almost the same screen time along with the same time since charge.. over 40% battery difference
