Air trigger problem
mr_strange
Rising Star II
When I'm using air trigger, i found out that even when i press the screen or back side near the air trigger, it gets triggered. DowsDoes anyone face the same problem ( sensitivity is set to around 1 to 3. Please help me because if I'm only having this problem, i can replace it. Thank you
71 REPLIES 71
Easoth
mr.strange
https://zentalk.asus.com/en/discussion/comment/31348#Comment_31348
Try removing the case and press the air trigger. It actually worked for me
The air trigger is working for me, but having the back of the phone also triggering the air triggers is really annoying. Did you managed to get your phone repaired?
mr_strange
Rising Star II
Easoth
https://zentalk.asus.com/en/discussion/comment/31454#Comment_31454
No. I don't think it as hardware issue because it partially disappeared with the latest update
Easoth
mr.strange
https://zentalk.asus.com/en/discussion/comment/31566#Comment_31566
Hopefully they push an update soon. I've contacted support and was told to factory reset the phone. It didn't work.
Other than that the phone is awesome so far.
bunnyfastard
Same issue. Please let me know guys if this is really a hardware issue. Already gave my phone to the service centre but they couldn't fix it either.
Attaching a video for reference.
Let me know if you guys have the same issue.
bunnyfastard
Hi All,
For people facing an issue with trigger working even when you touch the back of the phone.
I've found out a lame but working solution for now. I recently ordered and applied a skin for my phone.
Turns out, the trigger does not fire now when i touch the back of my phone (now with the skin). So look for some material and place it at the back of your phone (a piece of thick paper) and try if the trigger works then. If not, Voila! ? Just buy a skin or a small paper cutout.
I know this is not a permanent solution, but a temporary fix until the team
comes up with a solution.
Please try and let me know if this works for you.
