Air trigger problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-20-2019
04:17 AM
- last edited on
01-16-2024
12:52 AM
by
ZenBot
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-12-2019 09:13 AM
ROGuserIn the first post he said it shifted, and then that it was gone, and then that it was reduced. I need to give accurate feedback to the software team to know whether the fix is working or not.https://zentalk.asus.com/en/discussion/comment/33711#Comment_33711
I guess that is what he is trying to say over his last 2 posts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-12-2019 08:39 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-13-2019 01:16 AM
LP_ASUSYes . Exactlyhttps://zentalk.asus.com/en/discussion/comment/33569#Comment_33569
So before your left trigger was faulty, and after the latest update you are seeing the same behavior but on the opposite Air Trigger?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-13-2019 01:18 AM
ROGuserI too have this problemOk. Please take this feedback as well: The right air trigger for me (on .35 version WW) is buggy. At times, it triggers with a pressure of 1or 2, at times it doesn't at all unless you press it to a 7 or 8, in which it lags to register the touch, triggers multiple times (1-2 bullets at a time, instead of a spray). I know it is a software issue, because when I try to touch the air triggers outside the gameplay/ in the lobby/ control settings (to key map the triggers), it works perfectly. This was not an issue prior to the update.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-13-2019 09:21 AM
For anyone who is still having Air Trigger issues with sensitivity and is willing to provide a log, please reply in this thread and I'll send you the instructions as well. Thanks for your help everyone, we're working to resolve this as soon as possible for you.
