Air Trigger issue
nightsilvance
Experiencing some issue with my right air trigger. Button press is sometimes unresponsive and intermittent. Notice it after the latest firmware update. Sometimes the button press would "flicker" when I'm holding it down. Want to know if it's a software bug or hardware issue. Hopefully someone can enlighten me.
314 REPLIES 314
khanaish1997
Hope it will solve the issue
jairoconcepcion
basumataryneetu6
LP_ASUS... Send me the tool...
Disculpa pero no entiendo a que te refieres con la herramienta.
jairoconcepcion
sordeliel
I would be interested to get the tool. Right triggers is not working very well
A qué ser refieren con la herramienta? Yo no uso ninguna herramienta, el gatillo funciona mal por si solo.
jairoconcepcion
mamayankag
https://zentalk.asus.com/en/discussion/comment/27109#Comment_27109
Bro, it would be better if you remove the last screenshot, IMEI is a private info.
LP_ASUS
Anyone that still has the issue, we'd like to log your phone. If you are OK with this, please respond on this thread and I'll send you the tool.
jairoconcepcion
Gracias a todos
