Tuesday
Hello, I have a problem with the Background Mode feature after the latest Patch update that I updated yesterday, which is 35.1810. 1810.317. The problem I encountered is that when Background Mode is enabled and then I switch apps or return to the Home screen, the sound from the game will still come out, which normally, the sound would not come out if I did not turn it on in the Notification bar, which was a little shocking and annoying. And when I turn off the sound in the Notification bar, the sound in the game will disappear for a while, and then when I open any media that has sound, such as Youtube, Facebook video, the sound in the game will come back to overlap with the sound of the media that is opened immediately.
Thursday
I have no problem after the update, it works as it should. I advised the person with the background sound problem to reset the settings .
Thursday
9 hours ago
Thanks for the video, I'm sending it to the devs
yesterday
Здрасьте,проблема обнаружен, к пример смотрю фильм звонить ватсап звук ролика не останавливаются все ещё играет видео и звонить ватсап.
