11-23-2025 09:04 AM
My ROG Phone 9 can’t detect the AeroActive Cooler X Pro and it’s not working, but my phone still charges when the cooler is attached. Please fix this as soon as possible!
11-24-2025 02:25 AM
Hello @Lraee
If you are experiencing this then I would advice contacting your closest ASUS Service Center as this is not a reported issue so far, this way the service team can look into your cooler and see if there is anything unusual going on.
12-01-2025 12:44 AM
As it turns out, due to cost-cutting or defects, the contacts on the fan tracks in the Type-C connector have a poor protective layer against oxidation and deposits, which causes constant failures.
Actually, here's the solution:
12-17-2025 11:31 PM
Not really mine just perfectly fine using yesterday but then at around 12am i was about to put in my cooler suddenly it said need to update something so i did what the system said then i try to reattach back that's where my cooler stop working something work something not work. So i would blame the system that's trying to update which didn't even tell what are they updated to make the cooler stop malfunction anymore
