Aeroactive cooler x pro Issue
vividdayz209
My aeroactive cooler x pro is working when the usb-c is not plugged in, but when i try to plug the usb and try different modes it doesn't cools my Rog Phone 9 Pro after I detached the cooler,
maybe the problem was the cooler or the Charger Brick/Usb cable,
has anyone experienced something like this?
Mattias_ASUS
Hi @vividdayz209
We can continue here, I would like to ask you for a log so that the devs can look into this issue further, I'll be writing the steps down below and please make sure to recreate the issue before turning off the log tool.
Also, please feel free to send me a DM with the link for the log when you are done.
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
i can't reply yesterday because there's an issue in Recaptcha
https://drive.google.com/file/d/1MkGN5XrVXsmlRRuLZbtAYrLZGDyWOO9b/view?usp=drivesdk
Thank you for the information, I am forwarding this to the dev team.
