01-16-2025 08:14 PM
After the last update still problems with NFC payments. Please help.
01-17-2025 12:14 PM
Have you tried contacting your bank? Because the problem may be on that side
a month ago
Hello @michal_mateja19
If you go to Settings > Security and lock screen. Is your Google Play system update and Security update up to date?
3 weeks ago
Same. Nfc doesn't work after update. Pls fix
3 weeks ago
To clarify. My cards work. Tested with other phone. Nfc Google wallet worked fine before update now it doesn't.
