Battery drain in ROG phone 8
Panha
Guy, is it just me or the battery is draining much faster after the the update?
Gtoonm
Rising Star I
This might not be the answer you seek, but often after a firmware or software update Android phones erase some of the battery optimization routines they've built during normal use. So right after an update it's back to no optimization. SO it looks as if the battery drains faster than usual
I've had that with other phones. Keep up the normal use and it should eventually learn and optimize battery usage again. I you still see excessive battery drain, then we can consider it a bug.
Mattias_ASUS
This is fairly normal after doing an update, if this continues I'd recommend doing a factory reset.
hashtagbrar
The same is happening with my phone.
