Asus rog phone 8 pro charge problem
Vangelis
My phone doesn't charge from the main port the last two days , sometimes it connects and disconnects again ,i used the side one its better but with disconnecting problems too at least i can charge my phone , any suggestions?
8 REPLIES 8
Mattias_ASUS
Hello @Vangelis
Does this happen in one port only? Or both?
It happens at the main port ,the other works but with power cuts . The main port charges with normal charger if i shut down my phone
update now it doesn't charge at both only with a 5 wat charger
I m having both port charge problem for my rog 8 pro edition. What should i do?
