02-05-2024 02:22 PM
I have been waiting for this device for so long. I am very disappointed in the AIRTRIGGER. while shooting in the game, the trigger suddenly releases what it shouldn't. always been a fan of Asus and has always worked well, except for the Asus 8 pro model.
If you are really a gamer, I advise you to get an older device with a round edge instead of a flat edge.
The device also has no sensitivity booster. only what I can say "Too bad Asus", because I had a better expectation than the previous models
Solved! Go to Solution.
02-12-2024 02:21 PM
I heave the same problem whit rog 8 pro...
02-13-2024 03:51 PM
I received my 8 pro today and i only play CoDM. The trigger keys are a disaster. Why did they change a system that works great? i hope it can be fixed on the software side, otherwise it will go back to the dealer and i'll use my 6 until it falls apart. That really annoys me right now.
04-03-2024 02:42 PM
This is what I'm saying too even the 5 s worked perfect this thing feels like I just got ripped off the phones even perform same tasks in about the same time which is another thing all together
