02-05-2024 12:44 PM
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
Solved! Go to Solution.
04-10-2024 03:15 PM
It won't be it's defective triggers bro the pressure switches are different if they stayed as ultrasonic buttons would have been reliable but the slightest pressure on either side will cause the triggers to spas and also the screen itself probably because of the slim design too contributes no software fix for it there all like that
02-21-2024 04:03 AM
@Mattias_ASUS Any news on the air triggers update?
04-10-2024 03:16 PM
There ain't one bro there all defective they used different triggers this year and it's actually pretty terrible literally bad design slimming the phone and using pressure buttons
02-21-2024 01:18 PM
Same problem here. is this what we pay for? i shud have bought the other top gaming phone instead so dissapointed.
02-21-2024 01:22 PM
Yes this phone costs way to much for issues out of the box , but unfortunately RM also has issues
