Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
231 REPLIES 231
Which update u r talking about ?? Tell me ur update version
WW-34.1420.1420.407
More over this update version came long bk and still it's works like a dog **bleep** ..the fact this ASUS MOTHER **bleep**ERS still ignoring our complaints...we all sud sue this people and their cheap products
Alright twist your phone an update can fix that dude it's not updatable it's structurally weak causing the triggers to stick the fix is a recall not an update tested it still sht
deneskulik
Red magic 8pro is erzékeli ha csavarod a telefont, és ha izzad az ujjad már akkor sem tökéletes a triggere azon a készüléken sem, ezek nem fizikai triggerek, black shark 5 pro volt előtte, azok tökéletesek voltak mivel, fizikai gombok. Van még megoldás meg kell venni a hűtöt hozzá, és azon fizikai gombok vannak amivel tökéletesen élvezhető minden játék. Mellesleg nem is engedi túl melegedni a telefont.
