Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
231 REPLIES 231
GarbeGD
Hi everyone!,
I recently contacted ASUS to ask what was going on with the Air Triggers as I was planning to buy the Rog Phone 8 and this was their response:
"The Rog Phone 8 Pro device as far as the AirTriggers feature is concerned is no longer showing any bugs, you can purchase it with confidence."
What do you think?
I dont agree. This thread jas been marked as solved but the issue is still there. Not sure if Asus will work on it further.
What ? , no they are absolutely not fixed , I saw no change in the air triggers bug with update. @Mattias_ASUS  , what is this that Asus reps are saying the air triggers are fixed when they are NOT!
It is logical that the company tells you that triggers are not an issue while everyone in the community complains and they still haven't fixed it.. If I were you, I would either buy another phone or wait until they fix it
Can they still fix it ? is it a software problem? I really hate the auetrigger right now its so hard to push let alone holding it and its my first ROG phone and I'm starting to get disappointed by Asus.
