02-05-2024 12:44 PM
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
Solved! Go to Solution.
03-03-2024 12:19 AM
I think that the update will not change this bug, so I sent my smartphone back.
I'm afraid that this is a general bug, but I doubt it more and more, so I asked for a refund.
03-03-2024 04:19 AM
Good for you. In India we don't even have an option to return. Once we buy we are stuck.
03-03-2024 04:47 AM
I'm sorry to hear about your situation.
It is through amazon the return otherwise in France the return is not possible either.
03-06-2024 12:46 AM
Dear User. I am a Black Shark 12 GB user and I wanted to change to Rog Phone 24 GB (beautiful phone) wjat is most important for me is not money but triggers. Are hey that bad for PUBG and COD? What is most importante for me are side triggers.
03-06-2024 04:00 AM
The triggers on Rog phone 8 as of now are very disappointing. I would suggest to wait till @Mattias_ASUS releases some solution to the problem. Rog 8 is no doubt a good phone but the triggers are making me cry as of now.
