02-05-2024 12:44 PM
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
Solved! Go to Solution.
03-06-2024 05:24 AM
yes I had Wifi problems
03-02-2024 06:40 AM
Im going to sale mh device du too this issue and i think this end of journey with Rog phones even i wss expecting in uldate but yesterday i done and nothing happens
03-02-2024 10:51 AM
After the update there has been a small improvement, now we will see what will happen in the next one
03-02-2024 03:02 PM
I felt there was zero improvement, still crappy like before
03-03-2024 12:15 AM
@xxkstm78xx Agree with you . Still buggy nothing changed in update.
Only Cooler issue resolved in this update.
