Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
231 REPLIES 231
GarbeGD
That's great, thanks to Asus for listening to their community. Now we just need to test it in FPS and see if everything works fine now.
I can't wait for all the tests to be positive so I can buy this spectacular phone.
Thank you all very much and thank you @Mattias_ASUS .
errorTamilan
I am waiting release unlock tool
When release?
GarbeGD
Hi, I would like to know if the 16GB/512GB Rog Phone 8 Pro version comes with the AeroActive Cooler.
Does anyone know?
Nope , only the 24gb ram 1 TB model does
More now only at the release of the rogphone 8 pro 16g for 1 month, they offered the cooler.
Now that the 24g edition
