02-05-2024 12:44 PM
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
Solved! Go to Solution.
03-07-2024 09:52 AM
They are lying they only want you to buy the Phone.
The Airtriggers works yes but only by tapping (Sometimes even that dont Work) but when you need a Long Press in the Game especially in Shooter Game or racing Games etc.
It dosen't Work because the Airtriggers dont Work in Long pressed Button so that they dont recognize it that you are pressing long, means such Games you can't use your Airtriggers.
If you want a good gaming Phone i would recommend you redmagic thats what i will do the next time when i buy a new Phone.
This was my Last rog phone.
03-07-2024 09:56 AM
I agree and I paid €1200 to get a cell phone and the triggers don't work.. This is the last time I get an Asus..
03-07-2024 10:01 AM
yep Its so bad , I've been eyeing for ROG phone for a while and the moment I got one this happens . It really leaves a bad impression . This will be my first and the last ROG phone
03-07-2024 09:18 AM
Can you tell me exactly what the Airtrigger failure is? I think I've seen the bug is that when you hold down and lift your finger it stays down for like an extra second or so, I've also seen some people say they press on their own sometimes.
03-07-2024 09:26 AM
Before the update, when I pressed the trigger, instead of firing all the bullets, you fired 5 to 10.. Now after the update, if you have a little time to shoot and you go to press the left trigger, it doesn't fire.. In general, the mobile phone has an issue and since I see after an update, in general, androids are very slow...
