Aeroactive cooler x pro Issue
vividdayz209
My aeroactive cooler x pro is working when the usb-c is not plugged in, but when i try to plug the usb and try different modes it doesn't cools my Rog Phone 9 Pro after I detached the cooler,
maybe the problem was the cooler or the Charger Brick/Usb cable,
has anyone experienced something like this?
7 REPLIES 7
Mattias_ASUS
Hello @vividdayz209
So if I understand correctly, the cooler only cools when it's not connected to the power?
it only doesn't cools when i connect the charging cable in the cooler's usb port,
Can you confirm with me you are on the latest firmware 35.1210.1420.124?
 I can't see the cooler firmware ver. in my rog phone 9 pro, but i experienced the issues even before i update the firmware last week ig
edit:
i tried to use log tool and save it in google drive as i saw in other forum
is this the my aeroactive cooler x pro firmware ver. in the pic below?
