Rog Phone 7 not charging and overheating
TameezSeedat
Hasn't even been a month and I'm encountering an issue where I can't charge the device but when it's plugged in it creates a lot of heat
I have updated to the latest software, tried different Samsung adaptors and cables and still no luck
The phone isn't even a month old and I am facing this
Mattias_ASUS
Hi!
Does it work if you try turning off the phone and then charging it from the side port?
waxy78611
Zen Master I
Downgrade the software, I have made a post on how to downgrade
azwadrab
Rising Star I
Generally, it heats up a bit when charging with 65w with the bottom charger.
It's normal I think.
