Is there an audio quality difference between the headphone jacks on the cooler vs the phone?
Wavepush
Is there a difference between the jacks on the cooler 7 and on the phone, or is it just better position when gaming? And also if you used a wired type c earbud on the bottom usb port, is there any difference there?
Mattias_ASUS
Hi!
I'd say the 3.5 jack on the phone is better but I personally haven't really been able to tell the difference even after testing with different headphones.
The USB-C for the AAC is not for information transfer which makes the bottom USB-C port the only choice.
