02-04-2024 06:31 PM
Is it just me or does you aeroactive cooler automatically sets itself to cool mode after 4 hours in frozen mode?
X mode + is active and I'm on bypass charging.
02-06-2024 12:52 AM
Did you check your cooler & system temp in the armoury crate?
Might be the cooler itself throttle above 40c+ ( during gaming ) be reason why it switch to cool mode.
I just realize you can monitor your temp over there thus my cooler temp starts around 38c and systems 37c during evening as here weather's pretty hot ( 35c )
02-06-2024 01:00 AM
Yes I always checked the temp. It will show between 31°c to 34°c. Then a message pop up will appear that it will set to cool mode.
02-08-2024 09:11 AM
I tested my friend's aero cooler 7 for approx 4 - 6 hrs gaming ( without Xmode ) and nope i didn get any pop - up where it will auto switch modes if using frozen for too long, but i do keep getting ask to update cooler firmware everytime I connect either 6 nor 7 cooler
02-08-2024 11:04 AM
I'll try to check again and get a screenshot of it.
