Aero active cooler 7 connection issues
Shaniic27
Hi!
Need help, was playing a game a few days ago with the aero active cooler attached to my rog phone 7 ultimate when both the game and o.s. crashed, I removed the fan that deactivated and restarted my phone, then whenever I connect the fan after, it keeps repeating the connecting and disconnecting cycle rendering it unusuable
5 REPLIES 5
Mattias_ASUS
Maybe the PM hasn't reached you, I'll write it here instead.
Which firmware are you on? And have you tried clearing the cache in Armoury Crate?
And as a last thing, I wondered if you could help us by creating a log, that way the R&D team can check what could be producing the issue, I will write the steps down below
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
