08-12-2022 11:28 AM
08-15-2022 12:29 PM
08-15-2022 01:53 PM
delano888Pretty sure its confirmed at this point that ASUS's attempt to fix the horrid speaker quality made the audiomaxx software buggy as hell.I have noticed some issues afteral. Somtimes the phone freezes for a few seconds when I'm playing spotify and try to adjust the volume, then it keeps doing that, other times it works great. Sometimes spotify won't really play at all, keeps stuttering (on downloaded songs so no buffering).
08-15-2022 02:12 PM
08-15-2022 02:25 PM
Jesp.rWrong, you can't fix the speakers beyond what was stock. It has a single amp, unless you can break the laws of physics it won't work, period.Let's not be so drastic. The sound is not bad, it is more, I have already said several times that at least, for me, it is good, but I understand that there are many options for this. Some things need to be fixed, but I'm sure future updates will fix it. Comparing with Rog3, Rog6 sounds louder, and is heard with more stereo effect. Rog3 had a more "boom" effect that rog6 doesn't have, but for me, the sound of rog6 is good and very immersive. It is my opinion. It is true that it needs improvements, because there are many flaws, not only in the sound. For example, the Air triggers deactivate themselves (I have the flashlight and Xmode configured) and every so often it does not work and it is necessary to deactivate it and activate it again for it to work. Google services drain the battery a lot... slow charging not sure if it works well... anyway... it's a phone fresh out of the oven, the pro version hasn't been released yet. As long as Rog3's color banding isn't a problem, I think all Rog6 bugs are solvable. Let's hope so.
08-15-2022 02:40 PM
