ROG phone 6 heat issues
kazue58
Hi I've been using rog phone 6 primarily for gaming (mobile legends) and I'm getting around 40-42 deg celsius when running the game on 120fps with the aerocooler on frozen mode. Does anyone else have the same issue? It heats up even when using non gaming apps like watching tiktok but not all the way at 40+ deg. The phone gets too hot to hold sometimes and other flagship phones seem to handle the specs better in terms of heat. My phone has the latest software and is freshly factory resetted and also rooted (heat problems were present before root so not the issue). Would very much like to solve this problem so I can push this device to the max. Thank you 🙂
6 REPLIES 6
Hey,
Can you guys please share the log file?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
ZenBot
Community Manager
Community Manager
