ROG 6 WiFi Roaming and Connection Drops
Greys
Hello,
Since the Android 13 upgrade, my phone has been having many WiFi problems, especially with WiFi roaming and connection stability.
It doesn't handover smoothly, and disconnects completely before connecting to the next nearest access point.
These issues didn't exist on Android 12.
Any hope of fixing in an update soon?
Mansi_ASUS
Hey @Greys,
Could you please share a log file?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Wi-Fi ”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
You can share the log file with me via PM.
ZenBot
Community Manager
Community Manager
