Rog 6 speaker problem
Mimz
my rog 6 phone bottom speaker has a rattling sound at certain frequency (subwoofer n bass) , any solution?
14 REPLIES 14
Anonymous
Not applicable
Test it
But save your data first
 no change after reset, is a service center case
Ford
I have this problem too. Have you find solution? I think it about firmware.
Anonymous
Not applicable
Yes its a  Firmware trouble
Solution is Android 13 Update
Update is available
Anonymous
Not applicable
When is install you need to reset.
To much System Changes on A13
Old Config files makes trouble
Finally i took it to asus service centre and they replace it with new speaker, still warranty, 5 days work, solved.
