ROG 6 FRONT CAMERA & FLASH LIGHT ISSUE
After updating ROG phone 6 to WW 33.0610.2810.177 Front  Camera &.  Flashlight Stop Working. Anyone know how to fix?
11 REPLIES 11
MR_Farhan
Mine is same .. it has problem like you have..
cloud4919
https://zentalk.asus.com/t5/rog-phone-6/asus-rogue-phone-6-front-camera-not-working/m-p/403246/highl...
It firmware issue but asus said you need go to service center.
But no one solved the problem after service center
Mattias_ASUS
@goldenstar14213 These issues need to be checked by the Service Center, please reach out to your closest ASUS Service Center
KOKO85
Im having the same Issue front camrea not working and my finger print as well my phone is asus rog 6 512, its crazy i cant use or scann any thing on my camera!!! this issue need to be solved as soon as possible and it most probably happened after the update android 13.!!!!!!
