Best way to frankenstein two phones together?
nojima
My first Z6 got wet and the motherboard died.
Now I just dropped my 2nd one on the camera, and it must have severed an internal connection =(
The first one has a lot less runtime than the 2nd. Also the magic button on the 2nd one is dead.
Would it be easy enough to take the motherboard from the 2nd and put it in the 1st? Or should I just take the camera from the 1st and put it in the 2nd?
Thanks for any advice.
Mattias_ASUS
Hello!
I would recommend to contact your closest ASUS Service Center as I do not recommend to go full on Victor Frankenstein on the devices.
Just to clarify, do you mean a Zenfone 6? Or the ROG Phone 6?
