Battery usage graph and timings broken
smokeypsd
Hey all, on ROG6 here with the latest update. My battery usage tab in settings is suddenly not displaying correctly, graph is gone, and it will constantly say 0 secs since last charge. Tried rebooting, deleting/unisntalling data for Device Health Services but nothing is changing. The battery itself so much as I can tell isn't behaving differently
It looks like so in the screenshot I've included.
11 REPLIES 11
smokeypsd
So I actually tried clearing data again for "device health services" this time with a restart right after. It now seems to be displaying correctly again, might be worth a try Colin?
How do you do that?
smokeypsd
So go into your apps view in the Apps &notifications section in Settings.  At the top just type "Device Health Services" then like any other app goto the storage and cache section, manage space and "clear all data"
Tried it already no difference at all Graph still dont work and my battery level still stuck at 100% and i just got it back from RMA...
@colincsf If you still have this issue I wonder if you could maybe provide a LOG so that the R&D team can check what could be causing the issue, I'm writing down the steps to do it and feel free to send the log to me as a PM.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
