Battery fast charging wattage
Redlith
Model Name: ROG 6
Firmware Version: WW_32.2810.2209.195
Rooted or not: Not
Frequency of Occurrence: Always
APP Name & APP Version (If your issue relates to the app): N/a
is it normal to display "hypercharge 65" (see screenshot) though in steady charging setting it was setted up as "Ultra Steady(equivalent to 18W)". I'm expecting to see like "Fast Charging 18W" or "Ultra Steady 18W) instead of "Hypercharge 65" in lockscreen info. please respond admin.
p.s don't recommend me to update firmware for now.
10 REPLIES 10
Anonymous
Not applicable
Charge speed works
But display tells every time 65W
Check the charge time it changes with every Option
Cheers
(Rog6 User)
FunBike31
Zen Master III
Redlith
https://zentalk.asus.com/en/discussion/comment/243809#Comment_243809
thank you for your feedback, I'll wait for some fellow Rog 6 user to validate your experience.
OOT: is Camera api 2 "Full" enabled in your phone? mine is level 3 access only.
Level 3 is higher than Full, it corresponds to Full + functions added by the manufacturer
Lossani
It works as intended. I just tested it
It still says 65 Hypercharge but charger reports both 18W (2A * 8.5V) and 10W (1.2A * 8.2V) (varies a bit but might be the meter accuracy) in both modes. I have a ROG Phone 6
Redlith
FunBike31
https://zentalk.asus.com/en/discussion/comment/243916#Comment_243916
oh i get it. I'm wrong 😅. thought that full is better than level 3
Redlith
Lossani
hope they fix the interface if charged as 18W, it should look like "fast charging 18W" rather "hypercharge 65".
regarding power I have no question furthermore, just the interface. Mind if your phone displays the same issue? if not, what firmware is your phone in?
