Audio clarity issues
StillBlue
Model Name: ROG Phone 6Pro
Firmware Version: N/A
Rooted or not: N/A
Frequency of Occurrence: Intermittent
APP Name & APP Version (If your issue relates to the app): YouTube, Facebook, Spotify, other video/audio apps as well
I have noticed instances where my sound cuts out/fluctuates, The volume will stagger, like it goes up then down, or down then up as I'm moving the volume, if I'm trying to set the volume high to listen to something, it cuts out to a super low where it can barely be heard, this has only happened after the last week or so.
10 REPLIES 10
Seth_
"Firmware Version: N/A" - I don't think so. 220?
StillBlue
Seth_
It doesn't show it for me. That's why "N/A" is there (Not Available)
Unless I'm just blind.. but usually it'll say "Firmware version" or something of the like.
CHOOZR
Zen Master I
youre at the wrong page.
The software version is at the bottom, called software information.
The build number should be seen there
StillBlue
.220-0 is the end of the build number
