Aero cooler 6 drain battery and need to re-attached to to work on charging
rhyan
Model Name: Rog 6
Firmware Version:  33.0610.2810.159
Rooted or not: Not
Frequency of Occurrence:  Always
I noticed my aero cooler 6 when it attached it's consuming my battery even I'm not using it even in idle it drain my battery and when I'm going to attached some pop up noticed that low power to charge and need to re- attached, In notification there is charging connected device via USB it can't change the Power option to turn off this, is this bug??? Please see all my screenshot.
Mansi_ASUS
Hey @rhyan,
Could you please share a log for the issue?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
