WW_18.0840.2111.200 made my device unusable!
pwingman
Model Name: Rog Phone 5 Global
Firmware Version: WW_18.0840.2111.200
Rooted or not: Stock
Frequency of Occurrence: 1 minut
Hello all,
Last week my device updated to WW-18.0840.2111.196 and sins then the device gui interface restarts.
I solved this "restart" by doing a factory reset until ill got update WW_18.0840.2111.200 and then again after the update gui restarts where back, so again a factory reset to solved the issue, but this morning without any updates the issue came back after a "phone call".
Then i just left the device alone as i was sick of it and now I have Android Recovery screen saying "Can't load android system, you'r device may be corrupt you may need to perform a factory reset"
If I press "try again" device boots again and same thing repeats over and over.
My device is not usable anymore however it doesn't seem to be a hardware problem. (unless) storage is corrupting files. I created a logcat however I can't add links to this forum yet, can i send a pm to anyone?
Best Regards,
5 REPLIES 5
Irene2_ASUS
Zen Master I
Hi @pwingman
Do you confirm it´s been resolved for you after update 18.0840.2112.210?
Thank you!
