Wifi & Wifi-Hotspot Not Working
freakingrocky
Model Name: ASUS Rog Phone 5
Firmware Version: Android 11 (18.0840.2106.86)
Rooted or not: Not Rooted
Frequency of Occurrence: All the time
So my wifi & wifi-hotspot suddenly stopped working. They won't turn on at all (the hotspot says Error when I try turning it on from this screen). I tried booting into safe mode (doesn't work there also). Tried restarting it several times. Not sure what to do anymore. I don't wanna lose data so if you know how to fix this, Let me know.
515 REPLIES 515
Wifi and hotspot not turning on after latest update
ansariibad555
i also have issues number 1,2 and 4,5
please solve my problems
wifi and hotspot error.
call problem
SujitMaximum
Today i just faced the same error you guys are discussing on my rog5, Wifi and hotspot is disabled ..is there any solution to it yet ??
SujitMaximum
Are we only the one facing this issue or is it a gobal issue ? Will it be fixed by a update ???? or just ignored . ?
SujitMaximum
Yamini
The latest software update on my ROG Phone 5 has the following issues:
1. WiFi icon won't activate upon tapping it.
2. Did a soft reset and a factory reset to try to fix the WiFi issue, nothing works- all the pre installed My ASUS apps have also disappeared.
3. Unable to restore back ups.
4. Unable to turn on WiFi
5. Can't make phone calls while downloading any app or data in the background using mobile data. The person on the other end can't hear me and I can't hear the other person.
Anyone else facing the same issue? I've purchased this phone in May 2021 and have been facing issues ever since.
There was a previous mic issue where other person on the call could only hear my muffled voice.
This issue got better after 1 software update in June. But the latest software update ruined my phone completely. I'm not able to use it for any purpose.
Also, I've used Aeroactive cooler while gaming for a couple of days. Could that cause this issue?
Any leads or help related to the issue described above?
Yes there is some major issue going on..but i guess the rog5 team is sleeping..
