Wifi is not working for ROG phone 5s pro
prwaghulade
I have bought Asus ROG 5s Pro in the month of August 2022 and from last 2 months wifi is not working for my phone after update to Android 13. From last 5 weeks my phone is at service center & they are saying Motherboard is not working. I am not getting any status unless I ask for it & it seems phone is faulty. Just because of software update how can service center determine that motherboard is not working however other functions were working properly. In fact if I format it, WIFI works for limited time. It used to show error, once I switched to Hotspot.
From last week I am trying to talk to Asus service center number but I am getting same reply no one is escalating matter to higher level. I have been asked to wait for 72 hours to get call as case is escalated but now it is more than 96 hours but no call is received. I believe someone will at least bother to reply from Asus team and I want to ask sincere question to Asus team, do you really call such phones as Premium phone? We are spending our money & because of software bug phone is at service center for more than 5 weeks without any proper update to us. Pathetic service & repsonse from entire Asus team. I have been forced to buy new phone because your team wanted phone for 2 weeks, you need to understand how normal man can buy multiple phones just because of poor performance of your phones.
1 ACCEPTED SOLUTION
Accepted Solutions
@prwaghulade
Your case is currently in the final testing stage.
7 REPLIES 7
Arun1
I am also having the same issue of hotspot error after updating to Android 13. I will never buy Asus products in my life.....
@Arun1
Regarding the issue you have reported, please refer to the following FAQ to see if the situation can be resolved.
https://www.asus.com/support/FAQ/1006657/
If the issue persists, we kindly request you to send your phone for repair to further investigate the matter. Once you obtain the RMA number, please provide it to me so that I can notify the service center about your case.
I have sent you a message, you can provide your contact information and RMA No through the message.
I am not sure what is the problem with so called Premium device. Whenever I asked for it, they said motherboard needs to be replaced. It's stringent, moreover service center is more pathetic, they don't escalate or connect to technical team at all.
Falcon_ASUS
@prwaghulade
We apologize for any inconvenience this may cause.
Please check the top right corner and kindly share the serial number and details requested in the PM inbox.
