06-12-2021 03:56 PM
06-15-2021 03:31 AM
Anna-KinNo. Just use it as normal. No need of disabling anything in developer mode. Yes since 5G is not there in India you may only keep that option disabled. Rest as usual. Charge phone to 100% without using it at all. Keep it at 100% for 10 extra mins. Unplug and allow it to cool for 10min and then start using, as usual, what you would like to do. Run it down to 10% and share your SS with us.https://zentalk.asus.com/en/discussion/comment/171722#Comment_171722
Haha..
So, I reset the phone, then disabled always-on LTE from Dev options, refresh rate is Auto, 5G is disabled, so.. let's hope for the best.
06-15-2021 05:02 AM
ReaperzwolfFlipkart is no longer offering Replacement for ROG 5, because of Limited stock. 🥲🥲https://zentalk.asus.com/en/discussion/comment/171735#Comment_171735
Hopefully, you have also asked Flipkart for the Replacement!
06-15-2021 05:28 AM
Anna-KinYou should tell them that none of my business if the problem is with the phone you need to replace it as per your T&C, and if you can't refund back the money.https://zentalk.asus.com/en/discussion/comment/171739#Comment_171739
06-17-2021 12:04 AM
06-17-2021 04:20 AM
thejus44Hey, @thejus44 thank you for your suggestion, I was testing for the past 2 days.Hi! Did your battery life improve after following those steps?
