06-12-2021 03:56 PM
06-25-2021 02:40 PM
Anna-KinI installed it and felt this too :'((( I'm upset as heck.https://zentalk.asus.com/en/discussion/comment/173615#Comment_173615
I don't think restoring would have any effect as "Restoring" will auto-download all apps from Playstore and you will do that manually anyway.
But, I do recommend NOT TO INSTALL THE LATEST UPDATE, it reduced my phone's SOT by 2 hours.
06-25-2021 02:41 PM
thejus44In my case it would just be a restore from my old phone's backup which was sent to Google drive. All I backed up was wi-fi settings and apps though, pretty much.@Anna-Kin thanks for the warning! I'll keep that in mind. I didn't even know an update had come out tbh. Btw are you consistently getting 2 hours lesser or did it happen just once? It could be any number of reasons, that's why I'm asking.
@pingu780206 depends on what kind of restore you are talking about. If it's the default android restore then it should be fine. If it's a titanium backup I'd recommend against it. The point of wiping the phone is to completely clear any system level remnants from the previous version. So any kind of restore that doesn't interfere with that should be fine.
06-28-2021 10:36 AM
thejus44@thejus44 With the same usage as prior to update I am consistently getting lower SOT, I don't have apples-to-apples comparison of Screenshots, however, I do have a couple. I will sort them and upload them soon.@Anna-Kin thanks for the warning! I'll keep that in mind. I didn't even know an update had come out tbh. Btw are you consistently getting 2 hours lesser or did it happen just once? It could be any number of reasons, that's why I'm asking.
06-28-2021 12:20 PM
thejus44@thejus44 Here are two screenshots of using the phone till 50% charge was left@Anna-Kin thanks for the warning! I'll keep that in mind. I didn't even know an update had come out tbh. Btw are you consistently getting 2 hours lesser or did it happen just once? It could be any number of reasons, that's why I'm asking.
06-29-2021 12:37 AM
