ROG 5 low speaker sound
KFHFADEL
Any one suffer from low speaker sound after the latest update?
It's not as before the update
ROG phone 5 WW-31.0810.1226.139
8 REPLIES 8
Hi @keren_ASUS
No I don't tested I downgrade to Android 11 before they released 31.0810.1226.146
But you can say I just fix the speaker with cleaning the speaker with alcohol
The sound get better
@KFHFADEL Thank you for the update! Have a good one 🙂
Maheshr6565
Brand new device.... Came with zero battery wouldn't switch on after some fiddling  charged it full, updated to latest build the speaker volume is all over the place low volume crackling sound trash quality sound. Don't know if it will ever be fixed.
