PUBG MOBILE JOYSTICK STUCK TO LEFT SIDE
go_brioni16
Model Name: ROG PHONE 5
Firmware Version: 18.0840.2106.86
Rooted or not: not rooted
Frequency of Occurrence: often
APP Name & APP Version (If your issue relates to the app): PUBG MOBILE 1.5 and 1.4
Hello, I am having issue when I play PUBGM. The joystick stuck to the left side sometimes right side when I am playing. I need to retouch the screen to avoid this problem which is uncomfortable and even leading to lost game while in close combat. I played with Red Magic 6 pro which didn't have this issue. The ROG 5 has awesome screen however the mentioned issue is really making me to return the device back to the shop unless I find a solution for this. Thanks
go_brioni16
Isn’t there any moderator to help out?
himverma2012
Rising Star II
This is ROG-3 forum
Gustav_ASUS
Community Legend III
// Thread moved.
Are you using any kind of screen protector or 3rd party case?
I would suggest that you reinstall PUBG and clear the cache of both Armoury Crate and Game Genie, then try again.
